The Chevy Volt concept, shown at the Detroit show, is a car designed to be a plug-in hybrid from the start. The Volt is based on a roughly Cobalt-size platform and is said to weigh 3200 pounds, while a 160-hp electric motor drives the front wheels. That motor is powered by a 400-pound, 16-killowatt-hour lithium-ion battery pack (same kind of batteries used in laptop computers). GM says this massive battery, which stores as much energy as 12 Prius hybrids, can propel the Volt for up to 40 miles.
As long as you never use more than the battery’s 40-mile range, the Volt is simply plugged in at home and can recharge in six to seven hours. Electricity rates vary, but an overnight charge would cost about a dollar, yielding an impressive cost of just 2.5 cents per mile—cheaper than pretty much anything on the road today.
If all the battery juice is used up, the Volt will fire up its 85-hp, 1.0-liter, three-cylinder-turbo engine that powers a generator, charging the battery pack in about half an hour while keeping the car running. In the future, GM says the “generator” could be a hydrogen-powered fuel-cell instead of the gasoline engine used in the Volt.
This is a promising idea, particularly as a short-distance commuter that would rely mostly on cheap electricity, but even without plugging in the Volt, it would achieve about 50 mpg in normal driving. The major issue for a plug-ins, however, is the cost of the large lithium-ion battery. Based on the cost of a laptop battery, a unit the size of the Volt’s would cost somewhere around $40,000. But even if the battery cost $10,000, it would still be hard to make a profit on a mid-size sedan that would likely start around $25,000. Understandably, GM doesn’t expect something like the Volt to be production-ready for another five years.
