Замена масла в АКпп
Замена масла в АКпп
Всем привет.Хотел узнать преодичность замены масла в Акпп.На вид масло чистое и без запаха гари.Но вот когда его меняли незнаю?Через какой интервал пробега меняется масло?
Tahoe(840) 2000
Re: Замена масла в АКпп
Chevrolet Tahoe Maintenance
Every 3,000 Miles or 3 Months
Chevrolet recommends checking the power steering fluid level and transmission fluid level as well as changing the engine oil and oil filter every 3,000 miles. At this time, Nissan also recommends checking the coolant level, brake fluid level, windshield washer fluid level and tire pressure and condition.
Every 7,500 Miles or 6 months
Each time your Tahoe racks up 7,500 miles or 6 months of daily driving, Chevrolet first recommends performing a general inspection of the wiper blades and all hoses under the hood. Also check the battery, engine drive belts, cooling system and front disc brake pads. If your Tahoe is 4WD, lubricate the propeller shaft and the PCV filter, and replace the transfer case oil and wheel-bearing grease. Rotate the tires at this time to ensure even wear and tear is maintained.
Every 15,000 Miles or 12 Months
The 15,000-mile check includes an inspection of the brake system, fuel system, suspension, steering components, driveaxle boots and exhaust system. In addition, adjust the valve clearances, and lubricate the rear differential. Do these tasks in addition to the 3,000-mile and 7,500-mile maintenance.
Every 30,000 miles or 24 months
The 24-month or 30,000-mile maintenance schedule includes replacement of the spark plugs and wires, fuel filter, distributor cap, radiator cap and hoses, PCV valve and rotor. It may also be necessary to adjust the engine idle speed. Change the brake fluid, manual transaxle lubricant and transmission fluid every 30,000 miles. Finally, change the interior ventilation filter, water pump and timing belts.
by Google
by Google
302 / 289 / ex-133 turbo
С московской ездой, меняй раз в 30 - 40 т. км, хуже не сделаешь.
Понял.СпасибоDima писал(а):С московской ездой, меняй раз в 30 - 40 т. км, хуже не сделаешь.
Tahoe(840) 2000
