какой тип цоколя ?
- Fylhtq
какой тип цоколя ?
Добрый день, подскажите пожалуйста на Гранд 2000г какие лампочки идут на ближний, дальний и птф ? т.е. их маркировка цоколя (хочу галогенки поставить). Если не ошибаюсь на дальний и ближний Н4, а на птф ?
Re: какой тип цоколя ?
- Fylhtq
спасибо , но подскажи еще чуток, вот что выдал поиск по ссылкеGoaD писал(а):http://www.sylvania.com/ConsumerProduct ... mentGuide/
2000 JEEP Grand Cherokee (Limited model)
Low beam headlamp
9006XS
9006XSST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
9006XSCB Cool Blue: The whiter light for style. Up to 25% brighter light and up to 25% more downroad visibility.
High beam headlamp
9005XS
9005XSST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
9005XSCB Cool Blue: The whiter light for style. Up to 25% brighter light and up to 25% more downroad visibility.
Parking light
194NA
194NALL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
3157A
3157NALL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Front turn signal
3157A
Rear turn signal
3157
3157ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
3157LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Tail light
3157
Stop light
3157
High mount stop light
921
921ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
921LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Fog/Driving light
9055
License plate
168
168LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Back up light
3157
Front sidemarker
194NA
Ash tray
161
161LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Glove box
194
194LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Map light
194
Step/Courtesy light
214-2
906
906LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Trunk/Cargo area
214-2
Under hood light
561
561LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Instrument-general
103
PC74
какие меня интересующие лампочки сдесь есть?
- Fylhtq
с помощью гуглпереводчика, вроде бы разобрал )))
ближний - 9006
дальний - 9005
птф - 9055
правильно ли я все написал? поправьте если что...
ближний - 9006
дальний - 9005
птф - 9055
нуда
дальний high beam
ближний low beam
птф fog
дальний high beam
ближний low beam
птф fog
- Fylhtq
спасибо, а хотел вот еще спросить, НВ4А и 9006 это одно и то же?
9006=HB4. Если буковка - это просто модификация - пойдет, если это про увеличенную мощщность (не 60 ватт) - не советую.
- Fylhtq
спасибо большое за ответи и помощь !!!
9006 и 9005 в интернете полным полно галогенок (с белым светом, типо ксенон), а 9055 не смог найти, может плохо искал или таких в природе не существует? (имею ввиду с белым светом)
для ближнег ои дальнего хочу 6000К типо таких, что скажите? http://www.xenonshop.ru/product/MTF_Hal ... palladium/
я бы галогенки тока 4300 брал они самые яркие
- Fylhtq
Друзья, подскажите сайтик где есть галогеновые лампы с цоколем 9055 для птф ??? Рою интеренет, неужели таких нет галогенок?
6000К не бери, они даже по твоей ссылке описаны как "бело-голубые", а по факту они синюшные будут! у меня на тахе стоял ксенон 5000К и то он в голубизну отдавал
4300К самая правильная температура!!!
- Fylhtq
спасибо, по температуре разъяснили, спасибо! а с птф-ками бывают лампочки с белым светом?
ну я же ссылку выше дал
- SerGT
Гламурный розовый оттенокSilver писал(а):4300К самая правильная температура!!!
